1976 Johnson 70 hp wont come up on plane
alangore
I have a 1976 70hp Johnson on a 15 1/2' VIP fish and ski. I revs well beyond 2500 rpm in neutral. When Im under load it will not rev up and even stalls out while trying to plane. Will not go at all. I have replaced the CDI unit and the carbs are very clean. I have not yet replaced the plugs, but when I pulled them yesterday about 2 hours after being off the water they were still wet. Could the incorrect oil/fuel mixture cause this, and also would a low charging voltage cause it? I checked the charging voltage and only have battery voltage at the battery. I am an auto tech by trade, so this is somewhat new to me. thanks in advance for any assistance
Honorary Supreme Mariner
The ignition system does NOT USE BATTERY VOLTAGE to make the spark.-------------Did you remove the high speed jets found horizontally in the carburetor bowls.-----Do you have spark that jumps a gap of 7/16" on each lead.-----Reving the motor in neutral proves nothing as it will do that running on 2 cylinders.
alangore
It has been about 6 months since I had carbs apart. I will check those after I check for spark. thanks for the tips.
alangore
I checked compression it came up to 90psi in each cylinder after 5 seconds of cranking. Spark jumped over 1/2" gap with good crisp electricity. Is it possible the fuel could be too old? I am somewhat at a loss. thanks for your help
alangore
could the throttle linkage timing adjustment cause this issue. I rechecked my carbs last night and everything was clean and clear
Silvertip
Plugs are wet = too much fuel or not enough spark. Did you replace the plugs? Did you totally disassemble the carbs or just remove the float bowl? Your an auto tech -- you have an engine, so troubleshoot rather than shotgun.
alangore
Yes I totally disassembled the carbs, removed all jets and cleaned and blew air through all ports in carb. I have checked and have enough spark to jump a 1/2" gap. I changed plugs, adjusted the throttle/timing specs. I got it on the water yesterday afternoon. I came right up on plane. It ran for about 20 seconds and then died. I chcked the primer bulb, it was soft. I checked the carb drain, and it just barely trickled fuel. the motor has sat for about 5 years, is it possible the fule pump needs overhauled and should i move the primer bulb from the tank up closer to the motor? thanks
Check the fuel pump as it just may need a new diaphragm.----Check the pick-up tube INSIDE the fuel tank.
alangore
I have a kit for the pump already. I am considering replaceing all the fuel line as well as moving the primer closer to the motor. It has a portable 6 gal tank. Is there anyway to remove the pick up tube. thanks,
fireman57
There is a service bulletin to redrill the carbs on this engine. I have the exact engine you have and had the same problem. Easy fix with the bits and was able to turn them with a screwdriver type holder and now have no problem. I will look for the bulletin and the number but it is on here if you do a search. Mister Joe Reeves has sent it to me twice but every time I try to find it I can't.
fireman57
I bet if you bump the primer/choke when you give it gas it will get up and go. If it does then the above definitely applies.
