1976 johnson outboad 40hp only goes 12 mph
Joe Reeves
Re: 1976 johnson outboad 40hp only goes 12 mph
Check compression. What are the psi readings?
With s/plugs removed, check the spark which should jump a 3/8" gap with a strong blue lightning like flame... a real SNAP! Does it?
If you're not using Champion UL81J s/plugs gapped at .030, try them. If memory serves me correctly, that's what the engine calls for as per a OMC bulletin.
With engine NOT running but in gear, at full throttle, check to see that the throttle butterfly is opened fully (horizontal).
If you didn't manually clean the high speed jet that is located in the bottom center portion of the float chamber, do so with a piece of single strand steel wire.
Let us know what you find.
F_R
It is running on one cylinder. Two most likely causes are no spark on one and/or no compression on one.
crablegs
What size boat?
teelaw64
hi the compression readings are 115 on both cyl. i had spark friday i had it running in lake now i cant get it started looks like no spark i used spark plug tester motor calls for l4j thats whats on the inside cover but there useing b5hs this on 16' deep-v alum. the carb butterfly stays open horizonal when at full throttle
Joe Reeves
The L4J plug was superseded up to the Champion UL81J that I mentioned previously.
F_R
No matter what plug, it won't run if it has no spark. You gotta get into the ignition system and see what's wrong. That motor has the Low-Tension magneto. Probably dirty/worn/contaminated breaker points
teelaw64
yes it has spark i had the off swich off so good compression and spark i will change sparkplugs i put seafoam in tank seems like it wants to take of then backs down could a weak impeller cause motor not to run full speed
Tim Frank
Don't think so.
If you have any significant cooling problem, it unfortunately doesn't usually show itself until there is some major damage. :(
Not likely here, but if you aren't sure when the impeller was changed last, it never hurts to R&R.
Are you getting a good spark now...jump a 3/8" gap?
That plug (B5HS) is really hot....are you sure that is a reasonable x-ref?
Better to use the Champion.
Could be a fuel delivery problem. Check the tank vent. Check to see if primer bulb is collapsing. See if pumping the primer bulb makes it run better.
No, but a bad impeller could make the engine not run at all :eek: (after it's been toasted to a crisp).
Joe Reeves
As per my original reply "If you didn't manually clean the high speed jet that is located in the bottom center portion of the float chamber, do so with a piece of single strand steel wire."
If you're not absolutely sure that this jet is clean, do the above procedure. It may not be the cause of your problem BUT it is one of the usual causes.
