1976 Johnson Valve Body & Gear Case Assembly 0172857
cfish4448
I have a 1976 Johnson 85HP outboard and I believe the tilt/trim motor is missing some pieces to it. I am trying to find a valve body & gear case assembly, it is part number 0172857. Does anyone know where I can find one or if there is a replacement that will work for it? Thanks in advance for the help.
Honorary Supreme Mariner
Your location ?-----You might be able to adapt a Mercury outboard or Mercruiser stern dive pump and reservoir.-----The one that mounts inside the boat.
