1976 Johnson
MH133
Could Someone Tell Me The Solinoid Wiring For My 1976 40 Hp Johnson I Beleave Its Not Wired Right Im Not Shure The Hot Is On Right And The Other Side Is But The Two Small Ones I Dont Think Are Correct Thanks Again For All The Help Mitch
ezeke
Re: 1976 Johnson
You have one large post connected to the positive battery the other large post to the positive terminal on the starter motor.
You have one small post w/white wire running to the neutral switch grounding at the engine. The other small post w/white wire runs to the harness leading to the ignition switch. If the solenoid does not work, check the fuse near the solenoid.
