Seahorse16
Thread starter- Joined
- Jun 23, 2013
- 86
I'm been trying to diagnose my problem with my motor appearing to only be firing on one cylinder and figure out what I need to do. When I test for spark on the Upper cylinder, it jumps the 7/16 and 3/8 inch gap no problem. When I try the same thing on the bottom cylinder, it does not. To try and tell if the ignition coil is the issue or if perhaps the coil assembly under the flywheel is the issue, I swapped out the wire connections. The following videos show these tests.
To summarize the videos, I have good spark on upper cylinder but not on bottom. When I swap wires under flywheel, I seem to have good firing on the bottom coil and poor on the upper coil. To me, this suggests that both ignition coils are good, and perhaps the coil assembly under the flywheel for the bottom cylinder may be bad, but I am just a novice at this, so any guidance would be much appreciated!
Thanks...videos to follow (Note: disassembled and re-hooked things several times and got consistent results; some of the repeat trials are posted)
