1976 marquis 16ft boat locked up
boatermarquis
Re: 1976 marquis 16ft boat locked up
I'm about to take drive off and motor out and chop it up.(Edit; No solicitation on the open forum, use pm's)?
Redrig
what shape are the ball gears in ?
boatermarquis
I'll have to check when I get it apart.for some reason motor looks rebuilt.but drive looks original.drive may be fine.i couldn't get the trim to work at all.its trimmed up.dont know which wires to jump.wonder if that has something to do with it not starting.nuetral saftey
Redrig
definately could be , jump it at the starter sylenoid with the key in run
boatermarquis
How can I test spark with multi meter? It's getting spark, just not for sure if spark strong enough.i think it's gas in the oil not water.
Maclin
SInce you still seem interested in trying stuff before you hack it up....
You will hurt the multimeter if you try to use it for spark test, too much voltage, plus it is a spike that would not be visible for long. There are spark tester devices that can handle the voltage. Most workers just use a screwdriver or similar in the end of the coil wire and hold it close to ground to view spark. Yellow is weak, need more blue-ish arc.
Have you changed out the points and set dwell and timing yet? The amount of spark generated by the coil secondary winding is controlled by the points opening and closing events, duration of that is called dwell. If the points are in bad condition and/or not gapped correctly (controls dwell) then spark is diminished.
boatermarquis
Thanks for input.i sold title today for 125.so guess I have to chop it up now, but I can always look for boat that needs a outdrive.
boatermarquis
But not for sure to ask but I (edit, Cut it Out, or you'll be banned)
