kenny nunez
- Joined
- Jun 20, 2017
- 3,535
You should not try turning the inner hex screw. That is a pressure regulator and to adjust it a pressure gauge is needed, the wrong setting will blow up the outer tubes of the rams.
You are right about the fitting change. Try connecting the system like I described. If you luck out and find a good reverse lock valve then it can be re-connected.
