Timguy
Thread starter- Joined
- May 1, 2011
- 60
Hi, have no spark on one cyl. Problem happened while stored off season. Changed the switch box.....new CDI corp unit, still no spark upper cyl. Then stator tested poorly (just outside listed parameters) so replaced with new CDI corp unit......noticed old stator coating partially melted from before.....looks like one of the exciter coils got hot, but looked like it had run for awhile with melted coating. Still no spark one cyl so swapped wire between coils and got spark on the other cyl. We assume both coils ok then. What to do next? Could the old stator have damaged the new switch box before we changed out to the new stator? CDI corp. tech line suggested that could have happened. Motor is up at the lake and owner is not happy to say the least. Trigger tested ok too, at least before we changed the stator. Any other ideas? Thanks, Tim
