I just purchased this 7.5, everything checked out good on the motor until I pulled the LU drain plug. The oil was very thick, like bearing grease thick. I am thinking someone may have pumped bearing grease into the unit.
What would be the best method to get the LU cleaned up? I would hesitate to put any solvent through there for fear of eating up the seals. I don't think the motor was run this way for any period of time as it had a bad CDI before I picked it up, it seems to shift ok and the prop spins.
Run, flush, repeat?
Thanks in advance,
Tyler
Are there any manuals for the 7.5/9.9 posted up here?
Run, flush, repeat?
Thanks in advance,
Tyler
