1976 merc 850 question.
ed Hall
I searched the board and was suprised to come up empty. may be I am searchng to specific "Remove control cables from 76 merc 850"? Any way what i need to know is how to remove the control cables from my 76 merc 850? I need to remove the motor to repair the transome and to rewire the motor. it is ready to come off except for the control cables that i cant figure out out to remove. Any help would be greatly apreciated.
ed Hall
1976 merc 850 removal problem
I am going out to try again. wish me luck.
emckelvy
Re: 1976 merc 850 question.
Hi, ed, you'll notice where the shift and throttle cable come in on the Port side of the engine, right on the inside of the motor cowling there's a black, oval-shaped insert with 2 round holes into which the adjustable ferrules on the shift and throttle cable fit. There is a locking clamp assy that flips down and latches over both of the cables to secure them. To release, you'll see a little "tee" lever at the top of that latch. Just kinda push inwards at the bottom of the latch where it hooks into the control cable mounting bracket and the latch pulls upwards to release.
At the end of the throttle cable you'll undo the nut holding it to the throttle arm. Once the throttle cable is lifted up you can see the spring-loaded fixture that secures the end of the shift cable. All you do there is loosen the nut with a 7/16" socket (don't take the nut all the way off). Then, the shift cable fixture lifts up and pivots sideways to release the shift cable.
After that, just work the cables thru the rubber pieces at the front of the motor and you're free! Throttle cable goes out first, then the shift cable.
Note, when you go to reinstall the cables, the shift cable goes in first, the throttle cable last. The easiest way to tell which is which, if you don't mark them, is to flip up the fast idle lever; whatever cable moves is the throttle cable.
HTH..........ed
ed Hall
thanks going out to try again.
ed Hall
Thanks Lieutenant Cables came off and i didnt break anything! I tried lifting the motor off nad put it on my engine stand but i am not as young and indestructable as i once was. i can lift it but I cant do anything once I have it in my arms so I need to get my brother here to help. I want to post it as a boat project rebuild and add pictures. How do I post pictures?
