freeflyfool2000
Thread starter- Joined
- Jul 7, 2015
- 14
Hey there. I have what I hope is a dumb question. I am currently trying to remove the side mount control box due to a suspect electric shift switch. (Not getting 12v to fwd blade wire while in fwd shift position).
I removed the knob for neutral/shift cutout, then removed the snap ring thinking the shaft would then push out the back and let the box drop down for access. It isn't coming loose. Removed the 3 screws too. I assume they didn't build the boat around the control box...so what am I missing? Do I need to find a way loosen the inner piece with the angled notches? If so, do I need a special tool or will common tools work?
Again, I'm sure this is a dumb question, I just don't want to break anything.
