horsecapades
Thread starter- Joined
- Apr 22, 2010
- 35
Hello,
Thanks to CheapboatKev for pointing out that there is a Starcraft forum. I posted a topic in the general section and I got the distinct impression that most people don't like the big tin boats. Anyway..... I will repost my topic here in this section.
Basically, I wanted some idea of the value of my boat as is and if I were to restore it. I was owed some money and took in trade for my 800.00, a 1976 Starcraft Chieftain 25 mk iv. The boat obviously is just shy of 25'. It has an aluminum hull and has a mercruiser 165hp straight 6 engine. The lower unit was rebuilt and reassembled. The motor works seemingly fine. The hull appears to be in excellent condition. The cabin is dated and could use a good cleaning. The sink, stove and refrigerator work but the toilet in the closet does not. The table top is in excellent condition while the counter top will need replacing. The seat covers, both interior and exterior need to be recovered while the 2 captains chairs are in excellent condition, as is the engine hatch covering. The windows are intact. The Bimini cover will need replacing but not the framework which is intact. The floors are not entirely bad but are weak. My guess is this will be the most expensive job. I will assume that it makes sense to do the entire floor, both interior and exterior. This way I can fully inspect and paint the interior hull when the floor is removed. The electrical seems to be intact and all of the fixtures work. It also has a non-working stereo. The depth/fish finder works and there are several horns that also work. The instrument cluster is intact and I will, for now, assume they are working correctly.
This being said and considering I can do most of the work myself, I personally could see keeping it as a project. I cant spend the money if I cant justify the expense to my wife. If the boat could be done reasonably, then I could see doing the work for a nice looking boat as long as the cost does not exceed its actual value restored. This is the reason for my post. Was it a good trade, what is it worth restored, what is it worth as I have described it. I would appreciate any information you are willing to pass along. If I decide to keep it, I am quite certain I will use this forum for research and to help with all the things I thought I could fix, but really need an expert opinion on. Thank you, William
