1976 thunderbolt 115.
Shadow1234
I have read a little on this engine and people say if you have the wrong prop you can burn up the #3 piston. The prop i have is a SS 21pitch. So you think this will be the right pitch.
Droll
Re: 1976 thunderbolt 115.
To big a prop can AND will damage ANY outboard engine.... on the inline 6 engines the # tends to go first..
What size are your boat ?? ( length, weight, type of hull )
What WOT rpm does the engine have ?? ( WOT = Wide Open Throttle )
You should be able to reach 5500 rpm with a lightly loaded boat ( you + fuel )...
Quick example...
Got a 15 foot boat with a slightly "tuned" early 80s 90hp ( ported to 140 spec + 150hp carbs ).
  • Started with a 19 pitch alu propeller.... WOT rpm was 5100
  • Next tried a 16 pitch alu propeller... WOT rpm was well above 6000 :eek:
  • And just for fun tried a 21 pitch SS propeller.... WOT was 4800 rpm :eek:
  • Ended up with a 17 pitch SS propeller..... WOT now are close to 5800 rpm :cool:
Arne Kjetil
Chris1956
A 21" pitch prop is a bit tall for most boats with a 115HP inline six. If the boat is real light, it might be OK. I ran a 21 pitch prop on my 150HP inline, on my 16 foot avenger, which is 1000# in weight with motor. It was the most that motor could take. If your boat is heavier or has a deeper vee, it may be too much prop.
