1976 tilt n trim question
roofcock
hello all. hopefully everyone is having a good boating season. i am trying to start mine. i have a 1976 johnson with tnt. last time out last year it would not raise the motor at the dock. so i turned the valve and raised it by hand to get it home. i had not messed with it until recently because of busy schedule. after reading thread after thread i tried the hammer trick and it worked for a minute. before while under power the motor would not raise but did ok while barely moving. i am thinking my brushes may need cleaned or replaced. my question is can i remove the top of the pump and pull the brushes out and inspect / clean them or, do i need to drain the oil pull the pump and disassemble it to do this. it seems that it is hanging up and tapping with a screwdriver handle gets it going so i am hoping i can clean the brushes and get a little more use out of her. any tips or suggestions would be much appreciated, thanks in advance
boobie
Re: 1976 tilt n trim question
It would probably be best to take the whole mtr off and go through it.
RRitt
if you have a prestolite then just buy one of the cheap, new replacements and be done with it. If you have a Calco then muck around with it and try to squeeze out a few extra months. When the calco is beyond repair then throw it away. The prestolite pump was also used on OMC I/O. Replacements and repairs are cheaper and easier. You can find complete used (and running) pumps on craigslist for under $100.
roofcock
i believe this is the prestolite. is this correct? and if so is the link what i need. i hate to sound so ignorant just dont want to purchase something i can not use. thanks
http://www.ebay.com/itm/NEW-TILT-TR..._Accessories_Gear&vxp=mtr&hash=item1e67a54cdf
