gm280
Thread starter- Joined
- Jun 26, 2011
- 14,605
I was going to post a few updates with pictures along the way, but decided to post after I had something actually finished. So here is the gas tack finished.
As you can see I cut into the top of the 6 gallon metal gas tank to add a reed type fuel sensor. It was a little iffy to try and make sure it was located in a place the didn't interfere with the handle, the existing fuel gauge and fittings. But I finally settle on where it is installed. It gives me a super quick connection and disconnection to the front fuel gauge and be able to carry it to refill or whatever. I had to really modify the reed sensor and that was a little bit discerning. But if I messed it up, I would have to make a new one. I used a stainless steel BNC type quick connector and since the wires are already pulled for that type connection, it works perfectly.
Yes, I know this is way way over kill for a little stick steering setup, but I couldn't help myself after the ideas started flowing into my head back some years ago. If I would have simply rebuilt this boat to just fish, I'd be fishing years ago now. But stupidity gets the blame...I guess!
I powder coated the gas cap and then reassembled it again. I like the finish. However, I used PPG base coat with PPG clear coat final finishes on everything else. I only wish I could have made the original logos and mixing instructions like the original tanks had. That is coming for the second tank though.
So this is the final for the tank. Now I need to push to finish the transom cap and then the Live-well CUSHION is all that is needed to finish and install the engine. I haven't installed the seats yet, but they are merely bolt in place (already fitting and tried) so not much to really do. I'm waiting for the absolute final to install such things to not get them messed up while I work on other boat things.
More to come soon...
