I Have a 70HP Evinrude around 1976, there is no place to tell the model number/serial number that i could find anyways, but judging by the cowl and comparing the styles..anyways, motor ran like a top, until my cousin and i decided to hit the lake. He was driving in shallower water through a creek to get to the lake, when he hit a rock, or log, then ran through the mud and weeds. we weren't going that fast, through there until he decided to give it some juice which obviously when he hit the obstruction; the prop was wrecked, so i had a spare put it on, but now i have no power. I can start it and run the motor but at full throttle i might be going 9KM/H and it won't pick up at all. So i turned to some manual's for other johnson/evinrude outboards and i've come to a conclusion that the water pump/or water way is clogged, i just don't know for sure. There is no pee hole, or water indicator to check for, when i put my fingers by the water intake i can feel suction, and there are is a little bit of water droplets coming out of the 2 exhaust holes, but when i touch the top on the powerhead it is hot...Could i be on the right track, or is there sometihng else to look at...like i said the motor ran perfect, until my cousin hit the bottom, so i can't think its fuel, or spark plugs...even though i have checked those...This morning we took it off the dock to load it on to my trailer when we had it at 3/4 throttle and all of a sudden it took off like there was no problem...but now after slowing down we get nothing again..
we are pretty much lost. Is there anyway to clear out a possible obstruction without tearing the hole thing apart.
we took the LU off, except for the shift linkage under the cowl, because it started to rain pretty hard. If someone could point me in the right direction or confirm mine, before i take it to a dealer , that would greatly be appreciated.
thanks
-Brad
thanks
-Brad
