When I put the boat in the water, I pump the bulb, start the engine (easily), warm it up a second, and drive away. No problem. Engine runs smoothly through the RPM range. Perfectly in fact. I was out for about an hour. Get back to the dock, pull the boat into neutral, engine dies. Won't start again unless I use full fast idle, then when I try to put it in gear, it dies. Finally, I pump the primer bulb a bunch of times and get it going enough to put it in gear, and again it's perfect though the rpm range until I pull it back into neutral, then it dies again. Won't start unless in full fast idle. Pump the bulb a bunch more times, get it started, etc.
I have:
Rebuilt the fuel pump (could I have done this wrong?)
Decarbed with the 1 gal of gas/seafoam trick (twice)
Bought new OEM primer bulb, connections, and fuel tank
Removed idle jets (which looked nice and pointy) and shot carb cleaner in the holes
Any ideas?
I have:
Any ideas?
