1977 115hp Evinrude Lower Unit Question
dwilliam
Hello I am need of advise about how to remove the lower unit on my outboard. The Model # is 115793s. I have removed all the bolts however it seems that there is a rod still holding it together. Can anyone tell me how to do this. I need to change the impeller because the motor is not pumping out any water.
Thanks
D
DJ
Guest
Re: 1977 115hp Evinrude Lower Unit Question
The shift rod is under the bottom carburetor. It's easier to reach if the engine is in reverse.
dwilliam
Do I need to remove the cab to get to it?
