ozzgood2001
- Joined
- Jun 22, 2009
- 112
after re firing this motor after 12 years of collecting dust it seems to be pumping good water although i have replaced the water pump but ran hasnt given me a chance to retest. but when first fired the port side is warmer than the starboard side. now i figured air bubble. but that usually happens starboard side.... i pulled the rubber hose on the rear of the engine port side and had moisture as water seemed to be coming thru.. could i pull that hose and start the engine see if any crud finds it way out? whats the easiest way to blow out the water passages in the block? i feel theres crud in there somewhere... all the plugs were wet so running lean doesnt seem to answer it. i can def. do 123 count on the starboard side without even takin my hand off. on the port side 1 2 OUCHIE LOL doesnt smell hot but i know at idle this shouldnt be. will the extra pressure from the new pump clear this up? any help greatly appreciated!
