Re: 1977 15 hp evinrude won't idle
DO NOT use starting fluid, no oil in starting fluid.
First check what the compression is with a compression gauge, make sure you have good equal compression (report back) on both cylinders, 5 pulls should do it. Second , if the motor has been sitting for a while chances are the carb need to come off, be dissassembled, soaked in carb cleaner, washed with water and blown dry with compressed air. Pick yourself up a complete carb kit and replace all the internals. Screw the idle needle in all the way until seated and back out 1 1/2 turns, go from there.
PS- the starter has to come off to get at the right carb nut, just make sure you keep the bolt in the rewind stater and use something to hold it together (I use electrical tape)
Welcome to Iboats, we encourage buying from the Iboats store!
