1977 15hp Evinrude low RPMat WOT
davkrat
I have a 1977 Evinrude 15hp 2 cycle on my Valco 14' Dry weight of boat is 150 lbs, about as light as they come. The prop is a 9.5"10 three blade aluminum which I believe is the OEM stock prop size. I've rebuilt the carb and replaced the plugs. With myself (260 lbs) and my 9 and 6 year old kids it maxes out at 5150 rpm for 15 mph. Just me I hit 5250 rpm and 16 mph. Gas and battery are moved forward under the bow and I'm running the trim on the lowest hole to keep bow rise down. Also have a fin mounted on the plate to help get the stern up, I'm considering building a jack plate to lift the prop as the ventilation plate is about 1.5" below the transom. It's a 15" transom but the motor is more like 17". I tried a 2X2 under the motor mount to get the plate even with the bottom of the hull and it got me up to the above rpm's and speed, before I was only getting 13 mph with the kids in the boat so raising the motor got me 2 mph with a load. Boat is mostly used for trolling for kokanee with the kids, I'd really love to be able to hit 20 mph. I also intend to use it in shallow rivers for duck hunting, hence the jack plate intention to get the skeg up as high as possible.
Reading online I've seen several people claiming to get as high as 24 mph out of similar motor and boat with a 10" pitch prop. Motor is rated for 5500-6500 rpm and I am falling 300 rpm below that. Seems like my motor just can't spin that pitch prop. I am looking to replace the current prop which is lightly worn, wondering if it might be keeping me from hitting the power band. First I am considering getting a 4 blade 8" pitch aluminum. Figure with the boat empty I will hopefully hit the upper end of the rpm range and with a load still be in the power band. Also for running shallow in the river with a hunting load the lower pitch and 4 blade should help get me on plane at lower speeds.
I would also like to get a second prop, maybe a stainless 3 blade 10" pitch. For chasing kokanee around the reservoir (currently a 20-30 minute run with the kids in the boat) hole shot is not as important as top end speed and for the time being the kids are still a fairly light load.
My question is will a 4 blade 8" prop get me in to the upper range of the power band.
Is the 10" stainless worth the extra cost if my motor won't spin my current aluminum 10" over 5500 rpm?
Is there some other underlying issue I should look at if a 15hp Evinrude won't hit the power band with a 10" pitch prop?
Video of running it with the riser block: http://www.youtube.com/watch?v=beheazk_ElA&feature=youtu.be
Re: 1977 15hp Evinrude low RPMat WOT
You must first establish the condition of the engine.-----------Step #1 is a compression test.------------Is there a dealer nearby who might have a proper test prop to see how the motor performs ?
davkrat
Not in town but there are plenty of places within 30-45 minutes of here. Guess I'll have the comp checked. I need a new prop regardless and plan to try the 4 blade 8 pitch. Don't think it can hurt.
davkrat
Compression was an even 65 lbs. on each cylinder.
64osby
Sounds really low. Pretty sure it should be 100 to 120. Might be time to pop the head off and see whats going on. Could just need a new gasket and re-dress the head and block.
davkrat
Any good tutorials on pulling the head? I understand the basic concept of pulling the head and then lightly honing the mating surfaces on a plate glass with sand paper. I don't have the manual for this motor so not sure exactly how to pull the head. I sea foamed it today, haven't had a chance to get it out on the water and see if there was any improvement. Plenty of gunk came flying out the exhaust though.
My brand new Tiny Tach appears to have frozen too?
davkrat
Sea Foam seemed to knock down on the carbon. A ton of junk came out the back of the motor. Removed the hydrofoil fins and was able to hit 2650 rpm and 20 mph. Happy happy happy. Going to recheck the compression after I get a few tanks of gas through it.
AlTn
2650 rpm is a typo and you are showing 6250 rpm?..20 mph?...I'd be happy too...from the vid I was going to suggest you lose the fin....decarbing was an excellent idea and don't be surprised if you gain 15 to 20 psi in compression readings, I saw this increase in a friend's 1978 9.9 after decarbing
64osby
Sounds like the decarb did the trick. Run it a few times and check the compression again.
Nice.:)
