It looks like you are making good progress.
I can't wait to see it finished.
Do those 1/4" blinds pull pretty tight, they look beefy.
[IMG2=JSON]{"data-align":"none","data-size":"full","src":"https:\/\/forums.iboats.com\/filedata\/fetch?id=10567550"**[/IMG2]
Soooo.... are they water tight when set? Doesn't look like the head ends up smooth like an Olympic.... What do you do, a dab of goop? Never mind, went back and saw the pics of your stern rebuild. They end up dimpled. So, then the question is..... is anyone using Olympics with the shaving tool? Seems to be very popular with the Airstream folks. Shaving tool is not cheap, but the result is as close to a solid rivet as you can get.....
