1977 175 mercury stator problem
KCLOST
Re: 1977 175 mercury stator problem
I don't have exact temperatures when running my engine, because my temp guage doesn't have actual numbers on it....<br /><br />But I can tell you this. When running my engine at idle is just spurts water out of pee hole. This happens at the lake and on the muffs. when I get the motor warm and the stats open it really pee's hard. <br />At WOT my engine runs pretty warm, if not HOT... Because my temp guage is almost pegged on the H, (highest mark on guage). When I throttle down it immediately drops to the lower half of the guage...I'm not overheating it however, because the alarm never goes off (and I know it works).<br /><br />My temp. sensor is measuring metal at the head, it does not measure water temp. Your sensor could be different than mine, which would explain your readings (assuming it is working properly)<br /><br />When was the last time your impeller/water pump was serviced? If you don't know, I'd get it done just for assurance. I would expect some water out of pee-hole, even at idle. Also replace the thermostats.<br /><br />But if you're not overheating, You're probably ok! :D
Virago85
it was replaced last year at the end of the season <br />and the temp guage is new so is the sender mine will not pee unless it is turning about 1500 to 2000 rpm but my real consern was no water from exust ports no spitting are any thing I no the pee whole has no prasure going to it its just a by pass was just woundering about exust ports
KCLOST
You won't see water exiting the upper exhaust ports until the poppet valve opens at higher rmps... At idle speed it will just exit at the prop and pee hole..<br /><br />Are you sure that you're overheat alarm works?<br /><br />I don't want you to find out the hard way that something is wrong... If it is ok, you are probably fine....
Virago85
Yes Im shure it works thanks for the consern to be on the safe side Im gona replace the impaller and both thermastats all though at 130 I cant see there being a problem
