1977 55HP motor. does it look right?
qobra
i picked up a boat with this motor on it. When i got it, the top cover was just laying on it, not latched on or anything, so i am not sure if there is anything missing. i just picked it up today, so havnt had time to really look at it.
i know it might be hard from the pics, but heck, its worth a shot. i plan on getting a manual for it also. im pretty darn handy with a wrench so i plan on doing everything myself.
thanks
TiminIN
Re: 1977 55HP motor. does it look right?
Looks like everything is there. Have fun!
qobra
thanks!
so, what should i get done first (what are common part that needs replacing)...
ive heard water pump. for a '77 it looks pretty decent IMO.
TiminIN
Maybe you should post everything you know about the motor: How long it has been sitting? Do you know what does work on it? Starter work? Plugs correct size and gap? Any cracks in fuel lines? Etc.
qobra
well i just got the boat with motor today. i havnt even cranked it. ill give it a try. the cover is kind of dry rotted around where it mates to the motor, do i have to change it?
TiminIN
I would get as much fogging oil into it as I could, cylinders,crankcase and let it set for a few days before trying to turn it over by hand at first to start things slowly so you don't get any "start-up" scratches in anything. While the oil is soaking in, teardown and clean the carbs they are most likely hard varnished. Take your time and be patient. Also, read this: http://forums.iboats.com/showthread.php?t=158086
qobra
nice.. thanks for the link.
btw, the spring that connects to the throttle linkage looks really stretched.. is it suppose to be like that? i tried to snap pics with my phone, they did not turn out well. but ill try to find a pic of what im trying to talk about
