1977 70 Hp Evinrude Carb Questions
muledeer
I have 3 questions - Float drop adjustment - The carb kit i bought says to adjust it 3\4 inch but the manual i have says 1 1\8 - 1 5\8 . which one is correct
and with my kit i received a little spring for the pin float hinge do i use it, did not have one when i took it off.
also my carb does not have a needle valve(slow speed) just a jet.I assume it is 1 turn out.
Thanks for the help
