Backwaters2
Thread starter- Joined
- May 25, 2011
- 68
Need a little advice on my 1977 70 hp Evinrude. It's been giving me fits starting at the ramp when the motor is in water. At home on the muffs it fires up easily. With the added backpressure, it seems to wear down the battery and does not want to fire at the ramp, then the battery dies. Today same thing, fired up at home on the muffs then went to the launch and did not start. Tried additional jumper box and no help. Before I left, I rasied the motor out of the water and it fired up. Put motor in water and it restarted ok after that. Went for a test ride and the only thing I noticed was that the top end speed was slow. Did not seem as fast as it should for a 70 hp. Carbs were rebuilt last year.
Diagnostic:
Started motor under muffs: pulled top plug - noticed slight rpm drop
pulled middle plug - noticed slight rpm drop
pulled bottom plug - no drop in rpm's (not firing?)
So motor was running on top 2 cylinders only.
Checked spark - all three have good spark
Checked compression - Top Cyl - 100
Middle Cyl - 105
Bottom Cyl - 125
Checked bottom cylinder and it has water blowing out sparkplug hole. (Basically motor is running on 2 cylinders). Not sure if water leaking adds to a compression reading?
Wondering if changing the cylinder head gasket and cylinder head cover gaskets will correct the problem. Any other items that would cause water to leak into cylinder?
Diagnostic:
Middle Cyl - 105
Bottom Cyl - 125
