1977 70 HP Evinrude Head bolt torque
hawk200282
Decided to replace the head gasket on my 77 70HP Evinrude.
Wanted to see if anyone here had the torque specs for the different bolts:
Thermostat cover bolts, head cover bolts, and the head bolts.
Also, what pattern should I use when I tighten the bolts? I was just going to work my way up and down from the center bolts.
Thanks in advance.
boobie
Re: 1977 70 HP Evinrude Head bolt torque
18-20 ft lbs on the head bolts. 60-80 inch pds on the other ones. Any bolts on the head, start from the center and work your way out in a spiral pattern.
hawk200282
Thanks alot! About what I was thinking but wanted to be sure. :)
