Weirdboymike
Thread starter- Joined
- Apr 9, 2015
- 59
Hey there,
I have a 1977 70 hp evinrude model 70733s. I have been having control box issues for a few years and kept replacing the shift lever asm inside the box as it seemed to wear and shear teeth causing it to lock in forward due to the teeth jumping. Anywho I realized last year it was the shift cable that was seizing up so I just replaced it with a new cable and new shift lever asm. It is a lot smoother, how ever I took it out to the lake to run everything as this boat has gone through a major restoration. I noticed that sometimes when starting and attempting to go into forward gear it wouldn't shift but it would throttle up. I then went into reverse and it went into gear. After going into reverse I could then go into forward. It sometimes would do the reverse as well (wouldn't engage in reverse until I went into forward). Is this just simply a cable adjustment? I can manually shift just fine and the linkage moves when I move the throttle control on the box so I don't believe it is the shift rod. Thanks for any input.
