1977 70hp evinrude lower unit removal
1kkfan
Hello one and all. I am needing some help with my 1977 70hp evinrude. I am planning on replacing the water pump due to overheating. can anyone tell me how to remove the lower unit to gain access to the water pump. any info sent my way would be appreciated. illustrations or instructions would be great. thanks
Haffiman
Re: 1977 70hp evinrude lower unit removal
Remove the screw going through the vertical shift rod. (Under the carbs from port side)
Remove all screws holding the gear case, do NOT forget the one under the trim tab!!
1kkfan
sounds simple. we shall see. thank you very much
1kkfan
If anyone has any illustrations please pass them my way as well. thanks
1kkfan
sorry for the late response but thank you very much
