touch107fm
- Joined
- Sep 15, 2011
- 23
Hi guys
In need of some help / advice.
I bought my first boat about a year ago and I have being slowly restoring it bit by bit. Its a simple half cabin with a 1977 75hp evinrude. Over the past year or so I have learnt so much about motor engine but I am still learning.
My problem I have had the boat out on the water last week and now on Monday I brought it down to the water again but no joy it would not start.
I had a similar or the same problem a few months back I though it was resolved, I have been going crazy trying to fix it.
Being following the troubleshooting guide on the CDI electrics website.
Technical Support | CDI Electronics
So my problem is I have no spark on all three cylinders.
So far I have:
Removed yellow/black cable from power pack - no spark
Unplugged wiring harness and jumping starter motor - no spark
Cleaned all the contact and inspected all the cabling / wiring - no spark
Tried switching the key switch - no spark
I want to complete the next steps as per the support guide but dont fully understand how to test correctly (I feel ashamed asking)
I am referring to the tests for the:
Stator
Rectifier
Power pack
Coils
Base timing base
So here is the thing I dont know fully understand how to use my multi meter
When it say's to measure:
Check the stator and timer base resistance and DVA output as given below:
WIRE READ TO OEM RESISTANCE CDI RESISTANCE DVA (Connected) DVA (Disconnected)
Brown Brown/Yellow 400-600 400-600 150-400 V 150-400 V (*)
Black/White White/Black (all) 10-20 30-40 0.6 V + 0.6 V + (#)
Black/White Engine GND Open Open 150-400 V (a) N/A
White/Black Engine GND Open Open 150-400 V (a) N/A
What value on the ohms should I be using to measure these, also do you measure these in connected to the powerpack or no connected. Is this also tested with the ignition in the 'on' position. If anyone can explain or give me an idiots guide on how to test these that would great.
For the DVA values what setting on the mutli meter do I use.
I dont want to just start replacing bits for the boat, I am treating this like a big puzzle.
Another question, I know some of you will come back and say get the manual, Q. what is the different (apart from price between these :
1977 Evinrude 70 75 HP Outboard Motor Workshop Service Repair Manual Book | eBay
And the online one for general evinrude motors
Evinrude Johnson Repair Manuals Service Manuals
Any help would be greatly appreciated.
Darragh
So far I have:
Stator
Rectifier
Power pack
Coils
Base timing base
Darragh
