T748
Thread starter- Joined
- May 1, 2012
- 60
Re: 1977 Bayliner 2550
I didn't get much done on the boat this weekend. I did pull out the engine compartment/ cabin bulkead. A closer look at the fuel tank revealed some large corrosion pitting on top of the tank. The tank doesnt leak as far as I know, but will need to be replaced. 36 years is a good long life for a foamed-in tank. The whole project did get a bit smaller in spite of neding a new tank. I checked the condition of the stringers by drilling check holes every few feet. Dry! All I'll need to do is replace the transom, foam, sole and it's support structure and it'll be good to go! Well, it will still need an engine, outdrive, fuel tank, wiring, hole in hull repaired, gell coat repair, interior, exterior, galley, electronics,windlass and pulpit and... At any rate the project got a little bit smaller. Here is a shot of the the interior with the bulkead removed. There still is about 4' of rotted deck to remove. That and pulling the transom wood out is next weeks job.-Tom.
