Grub54891
- Joined
- Jun 17, 2012
- 6,465
As the title reads, this rig is starting hard in cold weather. 318 motor.
Little backstory: When we went to check out the rig, it was early spring, it cranked slow, but after messing around cleaning connections, and jump starting, it fired up ok. Bad starter. Replaced that the same day as purchased. Had no issues all summer, till now when the cold weather set in.
Went to start it last week so I could move it to its winter parking spot. Cranked fine, no spark-I actually put a spark checker on it. Wich brings us to today, I tried it again, still no spark. Power is at 12 volts at the coil, when cranking it drops to 11. Regardless, I got to thinking, when we were checking it out in the spring, it would not go at first either, so I left the ignition on for 15 minutes, went back and it fired right up. Now in my experience, a coil fails when its hot, not cold. Oh yeah, it's electronic, no points. Any thoughts of what could be the issue?
