cobaltboats
Thread starter- Joined
- Dec 7, 2011
- 6
I changed the water pump in lower unit. Re-installed lower unit. Hooked up shift cable linkage and forward gear seems to work fine, but I cannot get the shifter in reverse at all. I disconnected the cable completely from the engine and I believe it is in the shifter at the steering console. Forward back to neutral works over and over, but something is stopping it from even thinking about reverse. With the cable disconnected from the engine, the outdrive forward seem to work fine manually by flipping the lever on the motor. This boat is on a trailer in my garage currently. I have read if the shift rod gets turned on alot of these engines it will change the lenght, but I'm not sure it is an issue because the cable disconnected. It seems the mechanism in the shifter itself is the cause. Any thoughts would be very helpful, thanks.
