QuackAddict84
Thread starter- Joined
- Apr 1, 2010
- 25
Hey guys - I'm working on a 1977 4 hp Evinrude model 4706B. I picked the motor up in non-running condition, with a new water pump and "brain box" installed on it - previous owner still couldn't get it running. I noticed when examining it before purchase that the high speed idle jet was screwed all the way in. I rebuilt the carburetor, and got it started. It seemed to run ok on the water, but felt a little bit sluggish for what I expected a 4 horsepower to do (more like a glorified trolling motor.) I did notice that I also had to gently seat the high speed needle to get it to run at WOT. I did back it out a 1/16 to an 1/8 turn to avoid damage from lean mixture. I put a couple hours on it and decided just wasn't very powerful. When I went to winterize it, I noticed something interesting. The top spark plug was a little dirty (not more that expected for a few hours of run time), but the bottom plug looked like I just pulled it out of the box - brand new. It was not soaked with gasoline, just very, very clean. I though maybe it wasn't firing, so I rotated the engine with the plug outside touching ground, and the coil is firing it just fine. Both cylinders have equal compression - around 65 or 70 if I remember correctly. Is it possible that it isn't getting any fuel into it? What could be causing this? Thanks for any help; I greatly appreciate it.
