1977 Evinrude 55hp Adding gauges
DamianJP
Hey all
I want to add a Temp and water pressure gauge to this engine. The motor has this sender in the head, see pic. Which temp gauge will work with this sender?
Is there a place I can tie into the water system to get a PSI reading with a gauge?
Thanks ,
DamianJP
ezmobee
Re: 1977 Evinrude 55hp Adding gauges
(Caveat: I am not an expert) I think that "sender" is just an open or closed circuit to drive the overheat buzzer in your control box. I do not think it can be used to drive a gauge. You can buy gauges that come with (or separately) a sender that mounts on a little bracket that makes contact with the head. I found a pic:
http://i647.photobucket.com/albums/uu191/archbuilder/nescher pictures/IMG_0324.jpg
DamianJP
Cool Thank You Ezmobee
Cool seems easy to install. :) Are those kind accurate even tho its not embedded into head like the other one?
Can I install a water PSI gauge on this motor?
Thanks,
DamianJP
ezmobee
No idea and I think so :D
