Wetwilly62
- Joined
- Aug 12, 2018
- 50
Looking for the actual ohms readings I should get when testing the primary and secondary . Lots of videos on this , just not with my actual coil. Any help is appreciated..
Flywheel key checked ?
Have you checked where timing advances too?
Probably 5 or 6K ohms from the plug boot to the ground wire (secondary side) -- but my reference is old style under flywheel coils. I would recommend measuring spark to test strength of the ignition system, just using a cheap adjustable tester. Start with about a half inch, and work back if you need to until you have strong measurable spark:
If the flywheel key is sheared the timing will be off.-----Your timing light will still show timing to be correct however.
Flywheel key is in place.
Update on coil specs should be 200 - 400 ohms across secondary . Mine are 1290 ohms.
Spark is jumping 7/16" gap but now you are suspecting you have 2 bad coils ?
The oem plug is L77JC4. Gap would be .030. (Maybe what you are already using....)
