SHSU
Lieutenant Junior+Starmada Splash Of The Year 2019
Thread starter- Joined
- Mar 8, 2017
- 1,779
Howdy All,
Been chasing engine problems on my Starcraft rebuild I finally got back in the water (2 1/2 year project). If your interested in that, please see link in signature. As a note, since I have put so much blood, sweat, and tears into this project would really like to keep/use this motor vs buying new. I know its probably not the best decision and could be/has been expensive, but if you take a look at what we have done on the boat project you will understand the sentiment. Otherwise, looking to get some more assistance from ya'll on the motor and hopefully next steps. Please see information below and comment accordingly. As always, appreciate the assistance in advance.
Boat: 16ft Aluminum Starcraft
Motor: Evinrude 2 stroke
Make: 70773S
HP: 70
Power head Year: 1977
Cylinders: 3
Total Hours: Unknown
Background Info
1. As part of my original engine rebuild 2 1/2 years ago, I took the power head off and installed all new gaskets from exhaust to head. I did not crack the engine block as all the pistons looked good. Did complete rebuild of carburetors.
2. I did not replace any electronic components during that time. Fogged out the engine for storage while I worked on the boat. Did not plan on taking two years to finish the boat....
3. Fast forward two years, put the engine on the boat and fired right up. Ran for a little while on muffs then I shut it down, tried to start it again and noticed I got no spark.
4. At this time, I decided to replace a couple electrical components as they looked sketchy anyways as part of my "rebuild". Installed 3 new iridium spark plugs, 3 new Sierra coils, new CDI power pack, and new Sierra rectifier (Rectifier is what failed).
5. Took boat/motor out for first time back in July for maiden voyage at Lake Sommervile. Motor ran great and was able to reach WOT (~4500 - 5000 RPM)
6. Two weeks later, took it out to Texas City Dike (Saltwater) and started fine. Idled fine. Was able to reach WOT. Then I slowed down and put motor into neutral. Motor died, started back up, advanced the throttle and couldn't get past 2000 rpm.
7. Have troubleshot a couple things and taken it back out with no improvements.
8. Side note, live about an hour from any body of water I can test in. So only way to simulate back pressure on exhaust easily is to put it into a trash can at idle. (I know, not in gear and only for a short while as the water heats up quickly and doesn't provide proper cooling).
Things I have tested and tried since then (not exactly in the order below but tested):
1. New, non ethanol fuel, mixed with Pennzoil 2 stoke oil at 50:1 and sea foam stabilizer
2. Checked fuel filter/water separator, verified no water in fuel
3. Suspected fuel pump. Changed it out. No improvement (Threw this part at it....).
4. Checked compression, all three cylinders have 120 psi
5. Test I have done on Fuel system
a. Hooked up kicker fuel line to main motor and still had same issue. 8 hp Mercury 2 stroke kicker runs just fine and has been our "main" motor every time since my "Fixes" haven't worked
b. Verified all carburetors had fuel
c. Manually pumped fuel bulb and motor would not surge. Bulb would get hard and stop accepting fuel as the carburetor bowls were full while running.
d. Rechecked all the fuel lines. Redid all the fuel line clamps.
e. Cleaned out the carburetors again. Had issues with #3 cylinder (bottom cylinder) as pulling spark plug did not cause any major difference in RPM. Once cleaning done, RPM would drop when plug was pulled
f. Found some minor evidence of water in the #1 cylinder so changed out the head gasket again. I noticed the piston head looked way to clean through the spark plug hole and a couple little droplets on the spark plug head. Also, spark plug head looked much whiter then the other two. Installed new head gasket and made sure to properly torque the bolts down to 20 ft lb (Didn't do that before). Engine ran much better on the muffs but still issue once in the water.
6. Test I have done on ignition system
a. Moved coil packs around. Verified all coil packs working
b. Moved spark plugs around. Verified all spark plugs were firing and had good spark
c. Started engine on Muffs, individually pulled plugs. As stated above, 3rd cylinder had issues and were fixed by carb clean out again. Now, can pull any plug and RPM drop.
d. Checked idle Spark advance with a timing gun. Its showing at 4 degrees after TDC. SELOC Manual says it should be between 3-5 degrees after TDC
7. Changed prop to a 15 pitch from 17 pitch to reduce strain on engine. Figured with older motor it would help it out by reducing the strain.... Plus I wanted a better hole shot.
Current State:
1. Engine starts fine and idles fine in driveway. Sounds great too... But as others have stated, running on muffs anything can sound good
2. Once put in the water (back pressure on exhaust) engine has trouble starting/idling. When cold, engine will start and then quickly die out after 10-15 seconds.
3. If I start it and immediately shift into gear, give it a little throttle (While still cold) it will run for about 20-30 seconds before dieing out.
4. If I start, immediately shift into gear and advance throttle to WOT. Motor will get to ~2000 rpm and hold there. So we are moving at ~6 mph.
5. If I try and trim the motor or back off the throttle, the engine will die out. If I leave it alone, it will hold steady. Sounds like its not getting enough gas, but everything I have tried says fuel system is good.
6. Once "warm", it will idle a lot better and idle for longer periods before dieing out.
7. Often when it dies out, I have to try a couple times and choke the motor to get it to start.
8. The exhaust is a whitish gray. Originally was more blue when I first restarted it back in July, but think that was because #3 cylinder wasn't firing properly and had a lot of excess oil dripping out of exhaust pipe. Now, no oil drips out of exhaust pipe when sitting.
9. As we have gone out, the issue becomes worse and worse. Meaning after three trips to the water, idle time becomes shorter and shorter before it dies out, plus harder to start in water.
Next Steps/Question:
Not sure.... Hoping ya'll can help point me toward something I have done wrong or should check next.
1. Should I get a DVA to check the stator?
2. Should I recheck the power pack?
3. Any ideas on what my culprit could be?
As stated before, Thanks in advance
SHSU
Make: 70773S
HP: 70
Cylinders: 3
Background Info
Current State:
SHSU
