SHSU
Lieutenant Junior+Starmada Splash Of The Year 2019
Thread starter- Joined
- Mar 8, 2017
- 1,779
Thanks racerone ,
Glad I asked the question on the fuel line change. Any thoughts on why forcing gas through might cause the increase in RPM at high pressure? Gummed up carbs?
As for your other questions:
"Rebuild": I didn't do a true rebuild. Didn't crack the case and redo the cylinders. But took the powerhead off the outboard and opened everything else from the exhaust to head. Put in new gaskets and cleaned out those areas.
Flywheel key: checked and verified that TDC of Cylinder 1 is TDC.
Orange Wires: Checked that. Had the engine achieve WOT on first outing on this power pack before this issue started. The second time out, engine started up just fine, idled out achieved WOT then when I slowed down again, engine died. Haven't been able to achieve WOT since then. That was 3 or 4 trips ago.
Reed Valves: I will be checking those again when I pull the carbs off to reclean. One thing I noticed on this last trip was a lot of blow back out of the air box early. Then it stopped. So will be looking at those.
The change in RPM noticed was before I corrected the timing. I haven't checked that again and forgot to check. Glad you mentioned that.
Any other suggestions, please let me know
Thanks again,
SHSU
Thanks again,
SHSU
