Koldfusion
Thread starter- Joined
- Apr 4, 2012
- 4
Recently bought a boat with a rebuilt 1977 Evinrude 70hp Model 70773S. The motor was not stock, not sure if the controls were original to the hull or mated with the motor.
The bottom cylinder has a leak it seems. It is not moist to the touch so not sure if it is from before the work.
Can you guys take a peek and let me know if the motor looks good or not? Also, you pre mix gas with this gas correct? I see no reservoir for oil unless someone can point that out as well.
Thanks in advance.
Thanks in advance.
