BonairII
Thread starter- Joined
- Jun 7, 2011
- 2,727
Motor ran a couple minutes yesterday while I was working on the link & sync. Third time I started it...water wasn't pumping out of the telltale. Impeller is new btw. I pulled the LU and checked impeller/key, ran the hose up the intake and water came right out the telltale like it should. Pump housing is def connected to intake tube internally.
Put LU back on today and still no water pumping.
Checked compression just for the heck of it...and it's still good.
Motor has run fine on muffs before this problem. What could be messed up and causing water NOT to get up to the engine?
I'm getting a bit frustrated at this point, so maybe I'm missing the possible cause of the water problem.
