1977 evinrude slips in forward
DSimcoe
I recently bought a used boat, I had the clutch dog replaced in the lower unit and resealed. When the boat is out of the water I can put it in forward and reverse with the engine off and turn the prop. I can't get it to slip, as soon as I put the boat in water the prop slowly turns but won't engage completely. The motor rev's up fine. I toook it out of the water and again the prop was solid with the engine off. I started it and put it in forward and the prop turned but I can put my foot on it and stop it with some force. I don't have any problems in reverse. I've checked the shift linkage the height is correct and seems to be okay. What could it be.
F_R
Honorary Supreme Mariner
Re: 1977 evinrude slips in forward
Wow!!!!!Man, you scare me to death. You stuck your foot in a running prop? You don't know how lucky you are that you aren't on crutches now. NEVER attempt that again.
The problem is super simple. You have what is called a "spun prop hub". There is a rubber cushion between the propeller and the brass hub inside. The rubber is shot. Either have the prop re-hubbed or buy a new one.
DSimcoe
Ok.....So not the prop i got a new one and tried it out and it still did the same thing? Any other suggestions?
F_R
Impossible to say from here. But suggestions are:
Something wrong with the clutch dog installation, or the forward gear is totally worn out where the dog engages it.
Bent or worn out shifter parts in the dearcase.
A broken drive shaft
Stripped-out splines in the crankshaft.
You aren't really getting it into gear (linkage).
A broken shear pin. Nah, you aren't that dumb.
Daviet
What model motor are we working with?
