bryanwess2000
Thread starter- Joined
- Jul 16, 2008
- 240
To start off I had previously been using an electric fuel pump with this
motor after a few failed attempts to get the mechanical fuel pump to work.
So I decided to try again with the factory pump for safety reasons, my daughter now rides in our new(used boat). Anyway the problem is starting
out to get on plane sometimes it will bog down then cut off. If I prime the bulb on the fuel line after i start the motor then immediately go full throttle
I have no problems once on plane,the motor runsfine until I try to go over
32mph then after a few seconds it will slow down to 29 or so then I throttle
back a few seconds then i can throttle up to 32mph. With the electric fuel
pump it would run 36.5mph. Sorry no tach yet so I don't know rpms. The motor also dies after coming off plane and idleing for a minute.
I rebuilt the fuel pump except for the check valves which were replaced
a year ago. I also replaced the hose clamps on the fuel line with screw type hose clamps. The fuel line is just a cheap one from walmart,about a year old with no use time.
I wanted to know if it sounds like I have a fuel line/pump issue or a carb issue. I really want to sort this out for safety reasons, I don't like running the electric fuel pump with my daughter on board. And also for fuel economy with the mechanical fuel pump I can get 5-6mpg at 30mph, with the electric fuel
pump I can only get 3-3.5mpg no matter what speed. Any Ideas on helping diagnose the issue ? p.s I cleaned the carb about 3yrs ago and the motor has ran fine until I switched over to the mechanical fuel pump .
