Re: 1977 Johnson 115 HP will not WOT
I infer that your engine may be a recent purchase. If so, double check the engine setup. Make sure the full throttle position on the control box handle actually causes the carb butterflies to fully open. You will need to pull the airbox cover off to visually check to see that the carb butterflys are level at full throttle.
