1977 Johnson 140 HP motor weight?
RonnieD
Can anyone please tell me where I can find the accurate weight of this old motor? I have found answers ranging from 301 lbs to 365lbs, but would like to get a little more accurate in order to find a modern motor that does not exceed the weight of this one...THANKS.
V153
Re: 1977 Johnson 140 HP motor weight?
My '83 is purported to weigh 309 lbs.
Bob_VT
Yup right around 310......... too much to balance on your toes. Most of the older V-4's are the same weight
RonnieD
Thanks,guys.That helps me out...I want to find the most motor I can find in that weight ,since I am MAXED-OUT on weight as it is!:cool:
jimmbo
From the 1977 johnson brochure, 25 inch model with power trim 326 lbs, 20 inch with power trim 318 lbs, and finally the 20 inch no power trim 296 lbs.
