1977 Johnson 15R77M - WHERE DOES THIS PLASTIC PART GO?????
mjoppy
I RELACED THE WATER PUMP AND LOWER GEAR LARGE "O" RING - - BUT I FOUND THIS PART ON THE FLOOR WHEN I FINISHED. WHERE DOES IT GO OR FIT??? SEE ATTACHED PICTURES HELP!!!!!!!!!!!
AlTn
it looks like part # 0318972...impeller housing to driveshaft seal...parts diagrams for your motor can be found at various sites...one I use frequently is mar ine en gine dot com < one word dot com >...look under Gearcase section
oldboat1
+1. need a new seal, from the looks of it. shouldn't run it w/o a good seal(s) in place.
gm280
Break Down.jpg Another great place to see a break down of your engine is boats dot net
Here is such a break down. I think the part you are looking for is part #39
It is the Impellor housing to drive shaft seal... Part Number 0318972
Hope that helps...
mjoppy
Thanks folks I'll see if i can find a new one!!!!!!!!!!!!!!
