1977 Johnson 35 hp starting problems
kharrison
Just bought engine and when i tried to start it at home it had to turn over and over for a while then finally started.engine backfired once but then ran in a barrel of water for a few seconds and then we took it to the lake to try it out.when we tried to start it at the lake it did the same thing took a while to get it to finally start but only ran a couple of seconds and quit and wouldnt restart.it backfired once when first started.it is a electric start with steering wheel and johnson control box.any tips would be great.the box has one lever for gears and one for throttle,also do i need to pull throttle lever up very high for start?
5150abf
Re: 1977 Johnson 35 hp starting problems
The vertical lever is the throttle/gear selector, the horizontal lever is a timing advance for starting/increasing RPM in neutral.
Also the key should push in which activates the choke but it is only on if the key is pushed in.
Every engine is a little different but you should put the timing advance about halfway up, push in and hold key, turn to hit starter holding the key in, as soon as it starts back off the timeing advance as it should be running a high rpm and release the key/choke, you may need to tap the key in a couple times to keep it going.
Try that and see how it works, getting a 2 stroke gong without choke is next to impossible and I think that is your problem.
tashasdaddy
5150abf his is not the single lever controller, it is the two lever. i have one in the shop now waiting on connector parts.
the shorter of the the levers is the gear shift, the longer is the throttle.
Yes, you need to advance the throttle as far as it will go, activate the choke.
read this.
the motor probably needs service, don't blow it up, do to a bad water pump.
kharrison
Thanks for the info.This engine has a manual pull choke located on the engine and i noticed this morning when i pulled the engine cover off when i pull out the choke sometimes the choke doesnt close all the way.This might be some of the problem,also i never had a control box on a boat and didnt realize the gear shifter was a throttle also and the other lever was a advance for starting.Thanks guys for your help maybe i am on the right path now.
