flintcreek
Thread starter- Joined
- Apr 19, 2009
- 90
First bought this boat last year and have never had it run right. Compression is 140. It has new coils and jumps spark 7/16". It will crank and run for a short time when you choke it and then die. Pumping the bulb on the hose does not help. I borrowed my brothers tank and hose (known good) and it did not help. I am able to spray fuel mix in the carb and it will stay running. I have cleaned the carb with no change. I have also put a known good carb and fuel pump off another 35 that I have with a bad clutch dog and it makes no difference. What am I over looking. I have noticed when cranking with the choke closed it pops open when turning the motor over. Reed valves or other thoughts. Could it still be in the firing, it is CDI and I am not sure how to use a DVA meter. Ideals would be appreciated. I am about ready to carry it to a mechanic.
Flintcreek...
Flintcreek...
