1977 Johnson 70 HP low rpm's
DMontana
I have a 20' pontoon that I recently installed a 1977 Johnson 70 on to replace the 35hp that came with it and I am trying to get it set up properly, or as close as possible anyway.
It did not seem to give me as much extra speed as I thought doubling the HP would give me. (not expecting it to be a speed boat either).
I bought a 13-3/4" x 13 prop as recommended by the local prop shop. I just raised the motor on the transom 1", because it seemed to sit too low in the water and I trimmed it up 1 space.(no trim & tilt just manual)
This weekend I took it out and it seemed to have picked up some speed and ran great, but I hooked up my temporary tach and at WOT, I was only at 2000 rpm's. This motor's max rpm is 5000. So assuming that my tach was accurate, where do I go from here? Would trimming the motor up one notch have caused me to lose rpm's?
boobie
Re: 1977 Johnson 70 HP low rpm's
I would try a different tach. They can lie.
nwcove
im with boobie, and would guess that your motor is actually running at 4000 rpms. ( 2000 isnt much more than fast idle and you would not need a tach to know it was running at that rpm) jmo
xjdriver
Tach needs to be set to 6 pulses. And no, trimming up 1 notch wouldnt couse super low rpm's, make sure carbs are opening all the way, and timing advance is against the stopper at wot.
DMontana
Ok guys, thanks. I kinda thought the tach had to be off, but was not sure. I like the way it is performing so hopefully I can get my in dash tach installed this week and try again this weekend.
xjdriver
Ya, if you were moving faster than 5mph, you were turning more than 2grand, lol
xjdriver
I forgot, if the tach is set for poles its 12, for pulses 6. I guess some tachs are different mine goes by poles.
