ptremblay2009
Thread starter- Joined
- Sep 20, 2022
- 9
I have a 1977 johnson 75 that dies as soon as i put it in gear in the water. I can run it in gear with earmuffs in the driveway, but not in the water. I have replaced the plugs, 2 coil packs, fuel filter, cleaned the carbs and replaced the gaskets and nothing seems to make any difference. Checked the compression and all three cylindars are right around 120. Tried doing a cylindar drop test, engine dies when the first plug wire is pulled, but engine has spark on the 2nd and 3rd cylindar, and if i spray ether into those cylindars with the #1 plug wire disconnected it will fire up and then sputter out. The fuel lines are clear since i had to remove them to clean the carbs. But i am running out of ideas of what to try on this thing.
