MRneatfreak
Thread starter- Joined
- Feb 20, 2012
- 138
Been troubleshooting this motor/boat for some time now. I installed 3 new coil packs even though they probably didn't need it, and I have swapped power packs although I'm not sure they go with this motor. The numbers on them don't make any sense. Anyway it starts fine, and then after warming up a bit it acts like cyl #3 is out of timing and sometimes will stop the engine or if it doesn't there will be a puff of smoke out the exhuast. But if I disconnect cylinder #3 and run it, it seems fine. The carbs are off a different motor, but are practically new inside. I have replaced all the fuel lines, new primer bulb, fresh fuel, etc. I set the idle timing by cranking the engine with no spark and set it at 4 degrees btdc. I had some trouble with that, the screw was all the way in so that might be part of the reason. I don't know.. Also when I advance the shift lever all the way forward the timing base doesn't move all the way forward? Lost in the sauce on this linkage stuff. I have the service manual for this year and horse of engine, but...
Ugh, is there a Mega byte limit on videos? It won't upload 30 seconds of recording.
